SOLVED Slowness issues, strange colors. Enable Nvidia Gt 730 on monterey
Asus h110m-c
i3-6100 with intel hd 530
Nvidia gt 730
15.x
After days I finally managed to install monterey on my hackintosh. Only now the pc is slow, jerky, the colors are strange I would like to know how to configure my igpu (hd 530 intel) and then also enable my dgpu nvidia gt 730. thanks to whoever will help me
Attach a picture of GPU-Z to check the chip type.
Seems like its GK208 which is supported. Instead of using the NVIDIA GPU, it would be much better to use the IGPU. For the IGPU to work, do you have HDMI/DP port on your Motherboard?
i patched my nvidia and everything works perfectly now finally. now another curiosity. how can i go from monterey to sonoma?
That's nice. You can either perform a clean install or can upgrade directly to Sonoma. As the original issue is resolved, this thread will be closed.
Please create an additional thread for the additional issues you may have.
Reactions: Innovatekgalatina
bobawoz
