BCM943602BEAD Wi-Fi/BT not working on Monterey.
It was something along the lines of "this version is not supported."
Looking at the previous EFI, I made another one.The kexts included in it are:
  • AppleALC.kext
  • Lilu.kext
  • RealtekRTL8111.kext
  • USBInjectAll.kext
  • VirtualSMC.kext
  • VoodooPS2Controller.kext
  • WhateverGreen.kext
  • AppleALC.kext
  • Lilu.kext
  • USBInjectAll.kext
  • VirtualSMC.kext
Pay attention to the ACPI section. The reason for that error is because you're using an old SMBIOS which is not supported by Monterey.
Use MBP11,4 or later and you should be able to boot.
I modified the EFI from post #9. I changed it to MBP 11.4.Now there is no error as before, however, the laptop resets after a second.
Maybe we should try working with the EFI from post #11? On that one, the system boots up without any issues.
You definitely need to use the last EFI, from post #11. Just update the SMBIOS and check if it boots.
EFI #9 post not working. With update SMBIOS not working.
EFI 11# works but WiFi/BT not. Whats next?
khoi
