SOLVED Open core and Monterey Installation problems
As expected, your EFI is not as per the guide.
even following this guide the error is always there, then I tried to redo the efi via dortania's guide but the error is always there
Don't rush. Firstly create the EFI from scratch as per the guide linked above and we'll see how it goes.
nothing changed, same errors. I'm redoing the operating system partition in case that one is damaged
No idea without the new EFI you created. If you created/fixed the EFI, attach it here to cross check.
Nessuna idea senza il nuovo EFI che hai creato. Se hai creato/corretto l'EFI, allegalo qui per un controllo incrociato.
it gets stuck here
it gets stuck here
Why are you using USBInjectAll and UTBMap together? Use USBInjectAll as per the guide and map the ports during post installation.
Also, you must add -igfxvesa in the boot arg.
IgnoreInvalidFlexRatio is required for BDW and older.
I created utbmap by mapping the pre-installation ports. IgnoreInvalidFlexRatio in the video guide remains active but I will deactivate it. I will try as you told me and let you know. thanks
nnaa
