SOLVED Open core and Monterey Installation problems
You can use -wegnoegpu.
ok I'll try and I'll let you know, but if everything works will I be able to install the gt730?
Do I have to configure the integrated video card by inserting device properties as I did in the config.plist?
nothing to do it turns off immediately and says no signal and the pc remains on anyway.
I attach the opencore log
No idea without the EFI.
I redid the efi now the video problem is gone, but at startup it gives me a ban and I don't know what to do. I'm trying to install ventura. I attach efi
I redid the USB stick with Monterey and now the pc starts but it always gives me errors:
com apple.xpc. Launchd|2824-09-19 15:39:04.816232 (system) (warning>: failed lookup: name = com.apple.securityd.xpc, requestor = bluetoothdl182), error = 3: No such process
com.apple.xpc.launchd|2824-09-19 15:39:84,828446 (system) ‹warning>: failed Lookup; name = com.apple.analyticsd, flags = 8x8, requestor = bluetoothdE182), error = 3: No such process
com.apple-xpc.Launchd|2824-09-19 15:39:04,851093 (system) ‹warning>: failed lookup; name = com.apple.tccd, requestor = bluetoothdl182), error = 3: No such process
I don't know what to do anymore, I'm about to give up and keep Windows 11
ok i followed the guide. my motherboard does not have hdmi but only vga, how do i insert it in the properties device of the igpu card?
alvarg82
