SOLVED Open core and Monterey Installation problems
Asus h110m-c
i3-6100 with intel hd 530
Nvidia gt 730
15.x
Good morning everyone and sorry for my bad English (I'm using google translate)
I'm trying to turn my desktop PC into a hackintosh by mounting monterey.
I configured my config.plist with the classic opern core guide, at the start of the installation the apple starts, the progress line after not even 3 minutes black screen with "no video signal"
opening the opencore log I see the following installation errors:
00:000 00:000 OCC: Missing compatible GOP - Not Found
00:025 00:025 OCC: Missing GOP on ConOut - Unsupported
00:051 00:026 OC: Changed resolution to 0x0@0 (max: 1, force: 0) from Max - Unsupported
00:190 00:138 OCUI: Failed to initialise output
00:225 00:035 OCB: External interface ShowMenu failure, fallback to builtin - Unsupported
my pc configuration is the following:
i3-6100 with igpu hd 530
16gb ram
nvidia gt 730 2gb video card
i attach efi folder with plist. if someone can help me to make it work. thanks in advance.
16gb ram
Attach the EFI you are using.
yes sorry
I have a personal macbook pro from which I created a bootable USB stick and configured the config.plist. The only thing I can't insert is starting the PC with the nvidia gt 730 or with the intel hd 530
Ho un macbook pro personale da cui ho creato una chiavetta USB avviabile e configurato il config.plist. L'unica cosa che non riesco a inserire è avviare il PC con la nvidia gt 730 o con la intel hd 530
English only!
sorry but I'm using google translate and I copied the translation wrongly.
Did you create the EFI using the guide?
I used the dortania guide and then followed the skylake configuration which is what my processor is. But it is the video card that is giving problems because the installation starts but then gives an error of "no video signal"
Disable the GPU during installation!
mohthearrow
