SOLVED Open core and Monterey Installation problems
Simply. use the monitor that has HDMI and complete the installation with that.
I don't have HDMI output on my motherboard, only VGA, that's the problem
Damn. Then there is no way. You can try VGA to HDMI Adapter. But there is less chance that it will work.
what a bad luck. my motherboard also has DVI. Is there any way I can fix that?
found dvi/hdmi adapter but bluetooth error (which I don't have) is still there
That's normal. Were you able to reach the installer? If not, remove the NVIDIA GPU and then try.
Also, what macOS version are you trying to install?
I'm trying to install monterey, but I don't understand this bluetooth error when the pc never had it
Sometimes, the error always does not reflect the exact issue being caused. For example, when the Graphics does not work, there are random errors.
if I attach the efi could you help me understand? in my opinion I made a mistake in patching the iGPU
nnaa
