I've fixed the issue, as well as my audio problem. The two problems I have left are that I cannot change the brightness and I cannot see the battery percentage of my laptop.
Hi, if you dont mind , can you help me in installing mac os majave . I had similar hardware specification like you. sharing clover files can also be helpful.
Follow the guide here:
Hey there! Thank you so much for writing such a detailed guide. There are not many of them out there, and especially not authors that actually reply to their comments!
My graphics are unfortunately not working, and this is one of the last things before my new Macbook is completely finished (hurray)! I have 620 graphics and an 8145U. I have done everything in your steps here, but they aren't working quite yet. If you could help me, I would be eternally grateful!
  • EFI.zip
    EFI.zip
That's correct.
For sure.
Your file seems to be large. Make sure you're omitted the themes folder.
Attach your complete Problem Reporting files.
That's correct.
For sure.
Here's the new EFI without the theme.
Also got the IOReg and the output from kextcache. Strange stuff going on there.
Kextcache output must be attached as a .txt file.
The files are not upto the mark.
Following your guide here, using one of RehabMan's plist for the 620 graphics makes the screen turn off, while the rest of the laptop stays on. How can I combat that?
Attach your PR files to investigate further.
Similar threads
plxzo
