ASUS PRIME Z690M-PLUS D4 - i9 12900KF - 128GB RAM - AMD RX 5700XT - Thunderbolt HotPlug - OpenCore
screenshots above corresponds to all direction and guide above given
smfh... You're not going to believe this. I re-did everything and used same exact EFI folder on a different USB.... works now
  • Wow
Can you double check the file you have uploaded?
One last thing, if there is a way i can donate to you for the assisting could you please inform me of how. Only thing left for me to do is fix the bluetooth not working but im going to search around the forum instead of bother you
Maybe the previous USB was Chinese? Or you used a different port?
Yeah, sure. Thank you for considering donating to the site. We appreciate that!
To donate, you can click on the Donate button in the left navigation pane of the site. From there, you can select the desired amount and complete the payment :)
In case, if you have trouble finding the link, you can find it below:
What WiFi/BT hardware are you using? And what macOS version you have installed?
  • Love
Reactions: 1coolappdad
fenvi T919 PCI-E WiFi Adapter
Going to donate today due to the assistance given was top notch and is very much appreciated. Above i have posted the wifi/bluetooth maybe i read wrong but i thought this was both for wifi and bluetooth but maybe its only wifi​
  • Love
Bingo!
You have a fully compatible WiFi/BT.
doctor who thank you GIF
Still apologies for the delayed response!
The WiFi is on the PCIe bus and the BT is on the USB bus. Using a cable, the BT should work fine :)
Bingo!
Thank you once again! I am very happy with this! Doing a time machine backup from old laptop and moving to desktop so i can be more productive, going to suggest this forum to many others
  • Love
Sounds good!
zazau197
