1coolappdad
- Jun 2, 2024
- Asus
- i9
- Radeon RX 5700 XT
- 11.0.x
- Mac Pro
One last thing, if there is a way i can donate to you for the assisting could you please inform me of how. Only thing left for me to do is fix the bluetooth not working but im going to search around the forum instead of bother youCan you double check the file you have uploaded?
Maybe the previous USB was Chinese? Or you used a different port?smfh... You're not going to believe this. I re-did everything and used same exact EFI folder on a different USB.... works now
Yeah, sure. Thank you for considering donating to the site. We appreciate that!One last thing, if there is a way i can donate to you for the assisting could you please inform me of how. Only thing left for me to do is fix the bluetooth not working but im going to search around the forum instead of bother you
elitemacx86.com
To donate, you can click on the Donate button in the left navigation pane of the site. From there, you can select the desired amount and complete the payment
In case, if you have trouble finding the link, you can find it below:
Forum Contributions
elitemacx86.com
What WiFi/BT hardware are you using? And what macOS version you have installed?
Bingo!fenvi T919 PCI-E WiFi Adapter
elitemacx86.com
Going to donate today due to the assistance given was top notch and is very much appreciated.
The WiFi is on the PCIe bus and the BT is on the USB bus. Using a cable, the BT should work fineAbove i have posted the wifi/bluetooth maybe i read wrong but i thought this was both for wifi and bluetooth but maybe its only wifi
Thank you once again! I am very happy with this! Doing a time machine backup from old laptop and moving to desktop so i can be more productive, going to suggest this forum to many othersBingo!
You have a fully compatible WiFi/BT.
GUIDE - How to Fix Broadcom WiFi on macOS Sonoma and Later
How to Fix Broadcom WiFi on macOS Sonoma and Later This guide covers fixing Broadcom WiFi on macOS Sonoma and Later using Clover and OpenCore. By following this guide, you'll be able to enable Broadcom based WiFi on macOS Sonoma and Later using Clover or OpenCore Bootloader. This guide is...elitemacx86.com
Still apologies for the delayed response!
The WiFi is on the PCIe bus and the BT is on the USB bus. Using a cable, the BT should work fine![]()
Sounds good!Thank you once again! I am very happy with this! Doing a time machine backup from old laptop and moving to desktop so i can be more productive, going to suggest this forum to many others
