ASUS PRIME Z690M-PLUS D4 - i9 12900KF - 128GB RAM - AMD RX 5700XT - Thunderbolt HotPlug - OpenCore
Got it, thank you very much. I was able to quickly make the changes, except for --> changes - PCI0 to PC00 <-- not sure where this may be. Everything else you have informed i have quickly corrected
This can be edited using MaciASL in the SSDT-EC-USBX.aml.
  • Love
Reactions: 1coolappdad
@1coolappdad In case if you do not have access to any Mac or unaware of editing the ACPI files, here's the attached one for you. Just replace it and you should be good to go!
Thank you for the reply once again. Going to do right away, had other plans but now you have replied i am on it.
This is where she is now. Goes down 1 blank line every so often
Can you double check the file you have uploaded?
Are you referring to the SSDT-EC-USBX.aml ? Should be the one you have zipped, same one for sure
chirag11122
