Stuck at "start::512:successfully initialized ahci controller"
terminatordolenjske
HP ProBook 450 G7
Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz 2.11 GHz
Intel UHD Graphics
Hi,
When I run opencore it gets stuck at this line
Stuck at "start::512:successfully initialized ahci controller", I'm using DEBUG mode and verbose, attached are my EFI folder and my logs.​
Laptop specs
Intel UHD Graphics
ASIX USB to Gigabit Ethernet
Realtek PCIe GbE Family Controller
Thank you in advance for your help
Hi,
Laptop specs
Intel UHD Graphics
I now did it again with the guide and it opens opencore, then when trying to run it stops and gets stuck at the start of it.
Attached is my new efi, please help
Ouch. Seems like a wrong link was sent. Please adapt as per this guide:
I managed to get to the point where it would install macos reboot but then when booting from usb again would show same options "EFI", "Windows", "reset nvram". If I reinstall macos then it will get stuck in the install, i.e "X minutes remaining" forever
Attach the new EFI you prepared.
This is my new EFI
biff
