Stuck at "start::512:successfully initialized ahci controller"
IgnoreInvalidRatio is still not disabled.
is this causing that error? and also should i enable the re sizeable bar currently its disabled and again i am getting the same error for "
sorry i know i am disturbing you but i am new and unable to find any details for this error they say the error is in ssdt but i redownloaded everything then also same stuck there​
It should not be enabled.
Same stuck at start 512 successfully init. ahci controller is some bios setting causing this or efi folder?
Not sure if you made the changes yet.
pomchik_games
