hi i will ask a question even though most of you will just make fun of me
is there actually a way to run macOS 13-14x on an RTX 2060?
cause i want to know if its possible or not before procceding and im new into this stuff
i dont have an extra CPU at the moment and i want to know if its possible or not
last time i installed there was NO drivers compatible for rtx 2060 and i need help
if someone found a way to install rtx drivers on macos please tell me
No way and never be.
The GT 520 and the GT 610 is the exact same card, just different rebranding so I find it odd that the GT 610 supports 10.12 and 10.13 and the 520 doesn't
Do you have a working confirmation? Probably, GT520 should be supported.
hI, I HAVE INTELI7 10700k WITHOUT gpu ANDNVIDIA rtx 3060 IS THERE ANY CHANCE I CAN GET THIS TO WORK
WYLDE983
