Limitations
Desktop APUs
XVIII. Lynx (Liano)
  • Max Native Support: 13.x
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Virgo (Trinity)
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
HD7660D
XVIII. Richland
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
8570D
8650D
8670D
XVIII. Kabini
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Kaveri and Godavari
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Carrizo
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Bristol Ridge
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Raven Ridge
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Picasso
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
I have old AMD Radeon HD 4850, can it be supported by hackintosh?
Is not supported OOTB. Requires spoofing. Being a legacy card, it works fine till High Sierra.
thanks for your replied, it important for me
What EFI should i use for R5 5600g (Radeon Vega 7 integrated graphics)
cuz all that is too confusing for me
Is ryzen 3 4350g apu compatible?
Reactions: hyperx
is the Ryzen 7 7730U on the Envy x360 supported? how do you find what Vega graphics it has from within windows? BTW just downloaded OCSysInfo and the graphics codename reads Renoir
Yes, its supported.
*** missedclick
GabyXB
