SOLVED BT not working DW1820A on Ventura- Thinkpad X1C6
delltech1
Hello,
everything is working fine, except i cannot activate bluetooth, in ABOUT i see the Bluetooth as NULL.
I even applied the patch for PCI devices via HACKINTOOL, including the Wifi Card, in BOOT-ARGS i use -btlfxallowanyaddr brcmfx-driver=1 brcmfx-country=PL
Wifi is working great - no issues there. BT is clearly visible in Hackintool and FW is loaded - BCM_4350C2.
System report: Address: NULL
Chipset: BCM_4350C2
Discoverable: OFF
Using the latest BRCMPATCH 2.6.8
Injector
FirmwareData
RAM3
Using a Laptop Thinkpad X1C6 with the Dell DW1820A.
I checked already various CONFIGs with similar WIFI card but couldnt find any solution.
Hello,
Chipset: BCM_4350C2
Discoverable: OFF
Injector
FirmwareData
RAM3
What macOS are you running?
Ok i solved it, i had used the bluetoolfixup instead of brcmbluetoothinjector for Ventura, now BT works fine with Thinkpad x1c6 and Dw1820a.
Great. Marking Solved and closing this thread.
ryusuke17
