Intel AX210 Bluetooth not working on Ventura 13.6
You must attach the IOReg using the IOReg App. It seems like the USB ports are either not mapped or the Bluetooth isn't connected.
Please address me on what to do, thanks
I've no ioreg app on macOS, just the cli command, which I used to export that file
here it is, thanks
if I need to remap usb ports or the likes, please address me to a guide...
here it is, thanks
Yes, the Bluetooth does not appear therefore it does not work. As always, mapping is a must.
all sorted out, between this video:
and that link you shared (important the step where to map the usb port as INTERNAL)...
thanks!
Reactions: Miguel-1964
На Сономе завел без танцев с бубном.
Doud
