Limitations
Desktop APUs
XVIII. Lynx (Liano)
  • Max Native Support: 13.x
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Virgo (Trinity)
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
HD7660D
XVIII. Richland
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
8570D
8650D
8670D
XVIII. Kabini
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Kaveri and Godavari
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Carrizo
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Bristol Ridge
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Raven Ridge
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Picasso
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
hi, may i ask a question, currently i have thinkpad l14 gen 3 ryzen 7 5825u, can i install on it?
Please, AMD ryzen7 4800H with Vega7 integrated graphics laptop it's supported?
Yes, its supported.
This it's very good news. I asked because I tried a lot of time and get differents error's. I don't know which EFI that I maded it's better becose all of them stuck in some part. I tried some tutorials butt had one thing that I maded wrong. You had a link or some tutorial more specific to this model, please?
Reactions: fr4b3lo
So, I made all exactly but get the same error that before : black screen and ocb image failed. I create with installmedia osx Ventura in a Mac.
Attach your EFI to check
Very thanks,
So I managed install and the system boot correctly but now I had problem with GPU. The GPU apparently works because I had transparent windows and shows that I had graphics acceleration. But most of applications crash.
I tried o lot of tips etc like u will saw in my EFI and also try path SSDT-GPU-SPOOF with the information that I get on my linux (above).
Also when I open some application and check IOregister explorer in exact moment that app crash appears two redlines down the GFX0. On gfxUtil command (-f GFX0) I received this message: DevicePath not found!
Slot: 0000:04:00.0
Class: VGA compatible controller [0300]
Vendor: Advanced Micro Devices, Inc. [AMD/ATI] [1002]
Device: Renoir [1636]
SVendor: ASUSTeK Computer Inc. [1043]
SDevice: Renoir [12dd]
Rev: c6
IOMMUGroup: 5
\SB.PCI0.GP17.VGA_
moraWooChang
