Oops. You were supposed to send the verbose video, not the EFI. xD
For the EFI, try to disable RebuildAppleMemoryMap and enable EnableWriteUnprotector and then check if it boots. If not, try to disable SetupVirtualMap and then check. Make sure you have a valid USB installer. Do NOT forget to reset NVRAM after making the changes to the config.plist.
