HP Ryzen 3250U
What's the disk model?
Did you try booting from all the USB Ports?
Did you try with and without XhciPortLimit quirk?
Try to disable SetupVirtualMap and then check.
Try npci=0x3000 and then check. Remove 0x2000 first.
Provide the Laptop Main BIOS picture.
I have Hikvision E3000 SSD NVMe M.2 512GB disk.
I tried booting from all the USB Ports, with and without XhciPortLimit, with and without SetupVirtualMap, and with npci=0x3000. Still the same error BuildActDeviceEntry exit
Here is the main bios screen: 20231130_205408.jpg
Here is the main bios screen:View attachment 6923
Try adding nvme=-1 in your boot arg. If there's a firmware update available for the Laptop, update it.
Thank you very much for all the time you helped me! We tried many options, I added nvme=-1 and updated the bios.
But still nothing works, I don’t think there’s any point in trying to do anything else, apparently my laptop is definitely not designed for macOS.
I am getting stuck in this installation
Specs: HP laptop 15s Ryzen 3 3250u gr000au
Mother board: HP
Microprocessor:Amd Ryzen 3 3250u with integrated graphics card AMD Radeon Vega 3 graphics
Wifi card: realtek 82511
This is my efi file
i have same problem
can you create efi for me please !!!!!
i have lenovo idepad s145 15 api ryzen 3 3200u vega 3 graphics can you make it for me
can you provid your efi
Alez0903
