Tryting sequoia ( ryzen 3600, 1070 ti )
i didnt upload new video, but it still has the same loop
probably something wrong with your config and or bios setting
@Ezger What's the boot drive model? Seems like an NVRAM issue. Attach your EFI to check!
its a PNY cs900 ,
first try i had 2 partitions windows + MacOS
second try i have the full CS900 erased for MacOS
both same exact loop
@EliteMacx86 1 question though before i waste more time , i saw you activated the gtx 1070 on Sequoia , will it perform in games properly ?
if not , i ll just go for Tahoe or High sierra
i know its not supported on Sequoia
this is the last set of code that loops
looks like it is unhappy with your drive
also there is still no support for your nvidia card. you will not have hardware acceleration at all and the whole experience will not be very good at all
@EliteMacx86 any idea about my EFI folder ?
i could use the same EFI for High Sierra ?
its a PNY cs900 ,
Is that SATA SSD?
No, it does not work fully. Just partial that is why it is experimental.
The EFI you attached is corrupt as well.
EFI is corrupt.
i rebuilt another EFI to try Sonoma this time, but my usd ( used in sequoia ) is not detected in windows nor in any Disk management App
use another one that isn't broken?
yrri75
