Tryting sequoia ( ryzen 3600, 1070 ti )
@EliteMacx86 i have created another EFI folder from scratch
followed your video step by step
now i tested with Sonoma
it gives me the same exact loop
  • EFI.zip
    EFI.zip
  • 9a3c922b-257e-4fe1-900a-af87d65075ca.zip
i managed to fix that loop by Disabling the SecurebootModel in the Misc-security
installed macOS sonoma 14.7.8
no gpu ( working on it )
no internet even though i installed the RealtekRTL8111.kext ( this is very important , i have to fix this asap )
no audio ( dont care about audio for now )
i rebuilt another EFI to try Sonoma this time, but my usd ( used in sequoia ) is not detected in windows nor in any Disk management App
You mean SSD?
For Sonoma, you must disable the SecureBootModel to avoid loop state.
Great.
For GPU, patching is needed.
For Internet, check the Realtek chip model and use the appropriate kext.
For Audio, injecting a correct layout ID is necessary.
XChikuX
