sequoia watchgreen error "cpu unsupported" help :(
med
MSI B450M MORTAR MAX
AMD Ryzen 3700x 8-core
Sapphire Nitro+ AMD Radeon RX 580 4gb
15.x
I don't know what's causing this. I pulled an all nighter to make this and it still failed :(
specs:
Sapphire Nitro+ AMD Radeon rx 580 4gb
16gb ram
EFI: https://drive.google.com/file/d/1l_cRIcWx1V0f8DMu24mEJrr9kVFl93O2/view?usp=sharing
i used zen despite it saying on the website that it only supports up to high sierra, could it be that the patches are outdated? when I used opcore-simplify it said my hardware could support up to tahoe so I just ignored it thinking that the
Is devirtualisemmio On? Try turning it off
Reactions: med
If you mean the guide in this website, Yeah, I didn't follow that one. I did dortania because that was the first thing everyone recommended. I will check it out. I just thought I'd ask first instead of throwing all that work in the trash and restarting from scratch.
could you give me some pointers on where to go? im a bit lost
There are several things that aren't needed. What are your BIOS settings?
dih
