Help error in Sequoia
38Nic
Asrock Z790 PG Riptide
I7 13700k
Sapphire Radeon Rx580 8Gb
15.x
  1. Mac Pro
Hello, I have a hackintosh with this system: I7 13700K, Asrock Z790 PG Riptide, Sapphire Radeon RX 580 8G, WD SN850X SSD and I'm using the latest release of Sequoia. Sometimes, however, when I restart or boot up, but not always, it gives me this error. Can you please help me? Thanks. a.png b.png
Hello, I have a hackintosh with this system: I7 13700K, Asrock Z790 PG Riptide, Sapphire Radeon RX 580 8G, WD SN850X SSD and I'm using the latest release of Sequoia. Sometimes, however, when I restart or boot up, but not always, it gives me this error. Can you please help me? Thanks.View attachment 9967View attachment 9968
Attach your EFI to check!
Ok, thanks, I also use another Samsung 990 Pro 1TB NVMe SSD with Win11 and an 8TB Seagate Ironwolf Pro data HD for vst or Logic Pro libraries.
The SSD you're using is a bad choice for boot drive. Plus, your EFI is not as per the guide and problems are expected.
OK, so aside from replacing the SSD (which brands), how do I fix the EFI? Thanks
Adjust the changes in the EFI as per the guide.
nesmirt
