Fixing error after Mojave post installation
Hi there , accordingly to your last feedback, I tried your steps but as mentioned in my comments that the problem still exist. also I attached the required PR. thanks to reply and feedback.
Attach the new PR files.
Hi,
Ia there a config.plist for the Intel UHD Graphics 620, I've installed mojave using a lenovo ideapad 330 as a base.
But my laptop is a Lenovo ideapad s-145, and I cant make the graphics work correctly, it only shows 7mb o vram and acceleration does not work
Regards
Hugo
Hi,
Regards
Hugo
No PR files attached. Off-topic. Open a separate thread instead.
thanks for your reply.
I'll do as advised
Thanks
ps. what do you mean by PR files
kinakinoy
