Limitations
Desktop APUs
XVIII. Lynx (Liano)
  • Max Native Support: 13.x
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Virgo (Trinity)
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
HD7660D
XVIII. Richland
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
8570D
8650D
8670D
XVIII. Kabini
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Kaveri and Godavari
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Carrizo
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Bristol Ridge
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Raven Ridge
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Picasso
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
is vega 6 on amd ryzen 5 4500u supported
can i install macos Sonoma on amd ryzen 5 4500u
apu : vega 6
laptop
Hi Admin. I have question. I don't have an ethernet port on my laptop, so can i use my mobile phone's data for it with cable? And how much internet would it use?
Depends on what phone do you have? Is it iPhone or Android?
The data would be approximately 15-20GB.
hi, may i ask a question, can i install on ryzen 3 2200u with vega 3? or it have to ryzen 5 2500u?
dizzjk
