Error 0xe0030004 Please Help
Trojekkkk
Gigabyte B550 GAMING X V2
Ryzen 7 5700G
AMD Integrated Graphics
12.x
Hi. I installed macOS Monterey on my PC. I wanted to update to Ventura, but when I try to update and when I after an hour of installation select macOS Installer from OC, it keeps showing the Error 0xe0030004. Can someone help? I am using OC 0.9.5, and all my kexts are the latest versions.
Provide a screenshot of the error and attach your EFI.
Here's my EFI and a photo. It's spamming the error in verbose mode and showing also an 0xe00300004 error.
  • EFI.zip
    EFI.zip
The picture you have attached is barely visible. Please provide a clear photo.
It's the clearest i could do
Even when I do everything like in tutorial, it doesn't work
If you think you did everything as per the guide, provide the EFI.
The best would be to follow the video guide on the channel
イツミてんちむデモン(Real_That_Itsu
