Hello, please help me understand one issue Sonoma 14.7.4
Yes, that's right!
Yes, that's right!
Navigate to /Library/Preferences/SystemConfiguration and provide a picture of the directory contents.
Done.
Hello, will there be any more comments? Or is that the end of the topic?
Hello, why don't you answer? Are you doing well?
Hello,
Have been busy last week. Doing good. Thanks!
Just looked at the forum and replying now. There are tiers available if you don't want to wait and prioritize the responses.
Attach the CLOVER EFI which works correct (without battery) and the OC EFI that has issue. Don't forget to include the IOReg for each bootloader.
Hello, I got it, then it's not a problem. I thought something might have happened. I have attached the files. Thank you very much!
No worries. Can dump the System Information for both the bootloaders?
Hello,
I don't understand you, please explain.
Good evening. I have attached the files.
kcbednar
