BlackScreen macOS sequoia. please help...
zcvion
ga-b75m
sandy bridge i7-2600
rx580
11.0.x
CPU: I7-2600
GPU: RX 580
MOTHERBOARD: GA-B75M-D3H
I want to install Sequoia on Sandy Bridge.
I made an EFI by referring to YouTube.
I completed the installation through the created EFI, and the only process left is booting.
When I boot, the log screen appears and then the black screen appears.
I don't know what I need to modify.
Please help me.
I'm posting my EFI here.
This is another EFI made with reference from another place.
Can you tell me what more I need to modify in EFI, which is easier to modify between the first version I posted and the one I just posted? Please.
CPU: I7-2600
GPU: RX 580
Please help me.
The EFI looks fine. What's your GPU make? Hope its not XFX. What display connection are you using? HDMI, DP?
kcbednar
