Limitations
Desktop APUs
XVIII. Lynx (Liano)
  • Max Native Support: 13.x
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Virgo (Trinity)
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
HD7660D
XVIII. Richland
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
8570D
8650D
8670D
XVIII. Kabini
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Kaveri and Godavari
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Carrizo
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Bristol Ridge
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Raven Ridge
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Picasso
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
Yes, its supported then.
will graphic acceleration work for me? Just as if I had a discrete graphics card. Will the videos work? Will I be able to use the system as the main one without experiencing difficulties? I apologize for the inaccuracies, I use a translator
Yes, you will have a full Graphics acceleration with QE/CI. Yes, the videos will work. Yes, of course, you will be able to use the system without major issues. With some hiccups here and there, it all works fine.
thank you very much for your help! Only I have problems with SmBios, after interfering with it, the system stops booting. I moved kext where I needed to, but the graphics acceleration doesn't work, am I doing something wrong? Can I make this work without interfering with smbios?
Please create a separate thread and attach your PR files to check further.
Reactions: 666_StratoS_666
and what EFI folder i need to use ? u can tell me plz
Hi, first post here, I've been struggling for a week now trying to install MacOS on my Lenovo IdeaPad 3, it has an AMD Ryzen 3 5425U APU in it, followed the Dortania guide and I just get reboots or freezes during verbose.
I am going to build a fresh installer and EFI again tonight and give it a try again, I will post any errors I get on here.
Hello,
This is a compatibility guide and only compatibility related questions and posts are allowed. Please create a separate thread in the appropriate category. Also, fill out your system specs in Profile.
Is Ryzen 5 4600G (Vega 7) supported?
moraWooChang
