Limitations
Desktop APUs
XVIII. Lynx (Liano)
  • Max Native Support: 13.x
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Virgo (Trinity)
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
HD7660D
XVIII. Richland
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
8570D
8650D
8670D
XVIII. Kabini
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Kaveri and Godavari
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Carrizo
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Bristol Ridge
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Raven Ridge
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
XVIII. Picasso
  • Metal: Supported
  • H.264: Supported
  • H.265: Supported
can i do it with my r5 5625u? i don`t understand this lists a bit
Maybe a stupid question, but what about 7000-series Ryzen iGPU support? I can't really find what graphics core my 7700X has exactly, but I assume no(t yet)?
Unfortunately, not supported.
Hello, is Ryzen 5 pro 4650G supported?
Reactions: yaya3500
Should be supported.
Hello Admin,
You say that the Ryzen 5 5600H with Vega 7 is supported, what about Ryzen 5 6600H as it is using Radeon 660M igpu, is it supported?
Thank you
Hello Admin,
Thank you
Reactions: venmoo
alvarg82
