Okay, I made another thread!
Can confirm, this works with Nvidia GT 1030 2GB model and Ventura 13.4 as well
Does anyone know how to fix this? Find my and Maps apps don't render properly. I just upgared from Big Sur to Monterey and everything is working but this. Here is a scr of what I mean by this.
hi wanna ask why my hdmi audio are not working im using Nvidia GT 1030 2GB model and Ventura 13.4 only hdmi sound are not working other than works fine.
Well, it's very normal for the 100 series NVIDIA GPUs. Use DP to HDMI Adapter.
Would this guide work for the following configuration?
* native MacBookPro10,1 (late 2012)
* thunderbolt eGPU box
* Nvidia GeForce GTX 980 Ti (it's Maxwell, GM200)
* MacOS Ventura (or Big Sur, or Monterey) with OCLP
Should work!
Hi, I'm running into an issue where I can't enable the web drivers on Monterey using OCLP on my build. Works fine on Big Sur, but once I upgrade to Monterey and enable the drivers via OCLP, the computer starts up but no applications launch and the menu bar doesn't fully appear. Any idea what's going on? I can provide any additional information needed.
AMD Ryzen 7 5800X
ASUS B550-Prime
Nvidia GTX 1060 3GB
GabyXB
