Mouse laggy in Ventura
lnuy
ASRock B660M Pro RS/ax
Intel i3-12100F
Gigabyte RX470
  1. Mac Pro
Hi all I have recently build a hackintosh and I managed to get every working well expect for the mouse lag issue. I tried searching up online but didn't get any workable results.
I have mapped my usb using USBMap and all my use ports works. I also tried using a wired mouse, bluetooth mouse and usb dongle mouse all with the same result. The bluetooth mouse I used is the Logitech MX Master 3S
So far what I have tried was
- Disabling Above4G Decoding in BIOS and adding npci=0x2000 in boot arg fixed
Please let me know what else I should try, TIA
Do I need to upload my config.plist?
Are you using WiFi/BT?
Yes I am using WTXUP BCM943602CS for my Wifi and Bluetooth
Try to turn off WiFi and BT and then check.
I have tried turn off both WiFi and BT.
Using my wired mouse or dongle wireless mouse still have the same laggy cursor behaviour.
What else should I try to troubleshoot?
Thanks
Thanks
Attach your PR Files to check further.
Hi I noticed that when I am playing a youtube video the video will also lag/pause together with the mouse lag. Could it be actually be a system lag instead of mouse lag?
update: #1
System just crash, black screen but the pc is still running (fans and light in case still on). I only had 1 app open for about 20 mins which is the “Preview” app with 1 pdf file open that’s all when the system crash
It has also randomly crash when nothing at all was open just staying on the desktop.
I have sleep disabled.
Is there any crash log that I may be able to refer to, if yes may I know where are they located at?
I hope this additional info helps
Thank you
I have attached my EFI folder here. Thanks for the help.
Incomplete PR Files attached.
However, the EFI you attached is not as per the guide.
update: #1
Thank you
Your BIOS Setings seem to be incorrect. Attach your BIOS video including all tabs and options.
fly.gao
