Kernel Panic AppleACPIPlatform in Ventura
sad that I wasn't able to make it work until today. after redoing everything from scratch.
this is the last issue I encounter no other menu item but openShell.efl.
I only use propertreee to edit the config.plist.
additionally, I should mention, this time I used Monterey Instead of Ventura.
No idea without the PR files.
sorry I forgot to upload
The config.plist is still not cleaned. Seems like either you didn't make any changes or the changes were saved.
You need to follow the below for cleanup
I don't know anymore, if I can't fix it today I'll give up. I'm pretty sure I did the cleanup.
Well, its upto you whether to continue or give up. If you did the cleanup, why does your PR doesn't reflects such changes? Maybe you have missed some part or attached wrong PR Files.
alvarg82
