Yes, probably.
Ah damn ok
Oh, nice. I would recommend getting RX6600 or 6600XT if you have some Graphics related work.
Oh, damn. Did you check the seller's review?
Ok well I only do light gaming at most, but that's good to know thanks
I did and they had a good score, although it was only positive on the buying side, they didn't actually sell anything before (which probably is a terrible sign in hindsight)
There is a known performance issue with 400/500 series card on Catalina and later. Hence, its good to use 5000 series or later.
Cat Wow GIF
It's always good to buy products from a seller with a rating of more than 95% at least. That reduces fraud.
Ok well I probably screwed up then :(
Might be possible that your seller is getting the GPU from somewhere else :rolleyes:
In any case, if you paid via PayPal, you can raise a dispute ;)
Dortania lied to me?
:mad::eek:😭😭😭😭
:mad::eek:😭😭😭😭
wyattst99
