I see, thanks.
Do you know if there is a way to disable the DVI port in OpenCore?
Atm I need to remove the cable physically when entering MacOS 😅
Can be done by patching the ports. But technically, the DVI port should work. DVI to DVI or DVI to HDMI can work.
What an absolute W for Hackintosh.
I guess it isn't actually
But like its not an "absolute W for Hackintosh"
Yeah true I'm currently in the process of buying the same card you have actually
But the Ebay seller guy is being stupid and hasn't shipped it yet even though its been a week
Edit: Since I purchased it
Also what do you think about the rise of apple's Silicon chips? Are our days as Hackintoshers numbered?
Oh, nice. I would recommend getting RX6600 or 6600XT if you have some Graphics related work.
Oh, damn. Did you check the seller's review?
wyattst99
