Hello, I have done everything from the post but after OCLP installs and restarts, MacOS crashes at "AppleKeyStore: 12143:265 operation failed...". This error reminds me of the incident in June 2022, where Nvidia revoked the driver certificates and some people couldn't use their Hackintosh at all.
Removing "nvda_drv_vrl=1" from the boot arguments seems to be booting fine, but with no Nvidia Graphics.
I've been trying for a few hours to get rid of this error, but nothing works. Removed SIP completely, SecureBoot. Am I the only one experiencing this?
No PR Files attached.
Also, what macOS version you're trying on?
One HDMI and one DVI.
I removed the DVI and now works.
Thanks man!! :D
Are you using DVI Adapter or Cable? And is that DVI to DVI?
Unfortunately, not supported.
I see, thanks.
Do you know if there is a way to disable the DVI port in OpenCore?
Atm I need to remove the cable physically when entering MacOS 😅
ANARKRUTOI
