Can be done by patching the ports. But technically, the DVI port should work. DVI to DVI or DVI to HDMI can work.I see, thanks.
Do you know if there is a way to disable the DVI port in OpenCore?
Atm I need to remove the cable physically when entering MacOS![]()
