No, RX6800XT is supported on 11.4 and later.
Exactly. WEG and Lilu are mandatory
Mojave supports 32-bit applications. If you don't have 32-bit Applications use, better to upgrade to at least Big Sur.
Thanks a lot
I will try next week and will let you know if i encounter any problem.
Is there anyone here with a similar configuration who could provide an efi folder?
Thanks a lot
Surely.
The Tahiti Pro2 (HD7950boost) line in the table is blank.
I have one (HD7950 Sapphire Dual X Boost) and it works with macOS Sierra, High Sierra, Catalina and Monterey (I didn't test Mojave, Big Sur and Ventura).
List updated. Thanks for reporting!
Mojave should be supported. Big Sur should be supported as well. For Ventura, probably require OCLP.
i'd like to suggest a change, my HD 6570 doesn't work on High Sierra and multiple sources have suggested that support for lower end 6xxx series have been dropped in Sierra
Well, it could be your implementation. The above list is confirmed lists and most of the cards have been tested at our end or have been reported by the forum members and upon our verification, it has been added to the list.
HD6570 is supported and we have fully verified it at our end on Catalina. Not sure about the higher versions though.
Oland Pro - Radeon R5 430 GPU spoofing Monterey results so far:
0x682B ID (Cape Verde PRO) gives you proper resolutions, but no HW acceleration, no Metal
0x6790 Radeon HD 7970 gives you proper resolutions, but no HW acceleration, no Metal
0x6798 Tahiti XT (Radeon HD 7970/8970 OEM/R9 280X) - same as above
The original ID is
6611Oland [Radeon HD 8570 / R5 430 OEM / R7 240/340 / Radeon 520 OEM]
EDIT: attached PR files
Oland Pro - Radeon R5 430 GPU Monterey results so far:
0x6790 Radeon HD 7970 (no metal)
These would require OCLP.
kcbednar
