I have no doubt it will work in Big Sur, but this is not a solution. :)
Want to make it work in Monterey and later. And now, when I can make it work in Monterey after overloading the module, I'm sure there is a solution. I still think the problem is that USB hub is the cause and is not detected correctly, not the bluetooth itself. I think adding correct information to ACPI should help, but I have no experience in this section. Any help will be highly appreciated.
We'll have to investigate it then. Please join us on Discord!
Will this eliminate the THIRD_PARTY_DONGLE ? because of this I got one way airdrop :(
Depends on what BT hardware you're using.
Reactions: venmoo
I am using DW1820A, will this guide work? I'm planning to use monterey or ventura as AMD-v only work with them
DW1820A works fine.
Reactions: venmoo
Thankss, I will try after getting phillips screwdriver, it is hard to remove the x screw
Anyone here who could have an eye on my reports?
I use a Wi-Fi 6 Intel AX210 - BT card on macOS Sonoma 14.4 with OpenIntelWireless.
Key Mapping ist done and as far as I can see it works. Kext and everything seems loaded. I also tried to boot with:
-btlfxallowanyaddr
Wifi is working, but Bluetooth shows up only under USB, under Bluetooth the Adapter is NULL.
On Monterey the card works fully with Wifi and Bluetooth.
  • Reports.zip
    Reports.zip
-btlfxallowanyaddr
Incomplete PR Files attached.
System Report and EFI is missing.
macOS Sonoma 14.4 on KVM virtual machine via UNRAID.
1) Here is my EFI.
2) Systemreport attached.
3) Complete Kextstat attached.
What do you mean with PR Files? Which one do you need? Please tell me how exactly I can get what you want there...
Thx in advance!
1) Here is my EFI.
Thx in advance!
Have you passthrough the USB Controller or the specific BT Device to the macOS?
Attach a copy of IOReg to diagnose further.
hubalala
