Did you create the EFI manually or used OCLP?Hello!
After experimenting, I've found the way to make bluetooth work correctly. After boot it is detected as THIRD_PARTY_DONGLE, I connect all possible bluetooth devices and bluetooth module hangs and disconnects. After that module restarts and is detected correctly as BCM_20703A2. Attaching correctly working IOREG and printscreens and same files after reboot. OC config is the same in both cases. I've tried sudo kill bluetoothd, but then module restarts and still not detected correctly. Only overload helps.
Try to remove the Bluetooth kexts. Being a native AirPort Card, there shouldn't be a need to inject the kexts.
