Seems like you misunderstood. The issue in your case is you're using a Device path as key. Hence, the error. Read the above linked guide and re-configure the DeviceProperties.Ok i have that info but you told me above to get rid of that key.
Whicj key should i keep if you see i have 2 in device properties? Thks
If its not booting, attaching the verbose video and also attach your EFI you're using to boot.I took out that key you told me too ,no more error but not booting either
You don't need to. Use OCAT for easy .plist editing.Ok How would i change a device path as key
here is link to efi
i must be doing something wrong all it does is try to boot than says opencore with a small menu to go to windows
Jumping won't help at all.Thks still confused i am a newbie .I am trying CAtalina still not booting big sur.
