Help for DSDT
I took out that key you told me too ,no more error but not booting either
Ok i have that info but you told me above to get rid of that key.
Whicj key should i keep if you see i have 2 in device properties? Thks
Seems like you misunderstood. The issue in your case is you're using a Device path as key. Hence, the error. Read the above linked guide and re-configure the DeviceProperties.
If its not booting, attaching the verbose video and also attach your EFI you're using to boot.
Ok How would i change a device path as key
here is link to efi
i must be doing something wrong all it does is try to boot than says opencore with a small menu to go to windows
Thks still confused i am a newbie .I am trying CAtalina still not booting big sur.
Jumping won't help at all.
Open your config.plist using OCAT and provide a picture of the DeviceProperties section.
ok back to big sur
toks23
