Help for DSDT
Just tell me when you get it i'll delete the file from site thks
Hi was i successful this time?
Sorry link expired i'll try when you come back .Thks
You can use Google Drive if the size is more than 20MB.
I keep getting that error I put
OCS: Failed to calculate size of dict field containing <empty> as type data, context <PciRoot(0x0)/Pci(0x2,0x0)>
The issue is you're using PciRoot(0x0)/Pci(0x2,0x0) in Key for PciRoot(0x0)/Pci(0x1b,0x0). Delete PciRoot(0x0)/Pci(0x2,0x0) from key and you should be good.
ok Thanks i'll try that
but I
also have these entries that are needed how do i place that?
AAPL
framwbuffer
framebuffer patch
have a look at my config please you'll see that
I just don't know how to place it
but I
AAPL
framwbuffer
framebuffer patch
Ok i have that info but you told me above to get rid of that key.
Whicj key should i keep if you see i have 2 in device properties? Thks
toks23
