Need Help for Intel arrow lake hackintosh 265K MSI Z890 S wifi
The problem isn't just the BIOS and its settings. It's OpenCore. I have logs here and I'm working my way through them, but I don't understand everything. Linux and Windows 11 work perfectly with the same BIOS settings. Unfortunately, OpenCore doesn't. If you try to use the shutdown function in the boot menu, it restarts.
The problem persists regardless of the BIOS settings.
01 The PC goes to sleep, but can be woken up cleanly and used for work. If you shut it down now, it restarts.
02 If you work normally on the PC without putting it in "sleep mode," it shuts down and stays off without restarting.
However, everything works perfectly fine in Linux and Windows 11.
I used the debug version and also included a few logs from OC and the Hackintool. Thanks for your efforts.
Run the following command and then attach the output file:
log show --last boot | head -1500 > ~/Documents/bootlog.txt
So, the first problem is that if you shut down the system, the system restarts instead of being shut down?
It shuts down when working on the system? Is it intermittent?
seph3421
