File system check exit code is 8
oops sorry, I need to load the corrected one
Why the ResizeAppleGpuBars is not set to -1? You should also set Resizeable Bar to disable in BIOS.
itlwm shouldn't require AMFIPass.
If the BIOS does not have option to disable CFG Lock, then enable AppleXcpmCfgLock quirk.
Remove -wegswitchgpu boot arg
Why you have to restore a backup again? Is there something missing in terms of data?
I always keep a backup of my system drive, just in case
Still not as per the instructions. Please check previous post to see what changes to make.
For some reasons opencoreconfigurator didn't save the quirk changes, tried twice. Made the changes with propertree.
That's a nice strategy!
Umm, the main reason is the OpenCore version and the OCC should match. If mismatched, then it gets borked.
The EFI looks fine now. Are you still having crashes?
Yes.... After 4-5 hours of usage. About the same thing than at the beginning.
That's weird. Can you explain the scenario how and when does it crashes? Is it random or during any specific workload? Attach the logs from /Library/Logs/DiagnosticReports. You can zip the last directory and upload.
Alisson de Santana
