File system check exit code is 8
I didn't install any as far as I remember... This install is an updated Sonoma hackintosh. But I'm pretty sure I didsn't install any kext in L/E as we use to do years ago.
Nice then!
Do I need to reset NVRAm after all those changes ?
Yes, correct.
Where can I find them ?
You can boot using -v and then attach the logs. Before that you should do what's instructed above.
Remove watchdog=0. Restart and boot into Recovery mode. Scan all the disks and partitions, including child ones. Reboot and you should be good to go.
Thanks a lot !
The SOS passed on all drives/childs with no errors except my external Linux SSD, but I guess it is normal.
Next step is to try again a escuezilla backup.
You think that all those stuff could be the reason of the random freezes ?
I made all changes, and I have the -v arg, but I don't know where those log files are located...
Why you have to restore a backup again? Is there something missing in terms of data?
Probably, yes.
You'll have to record.
How do I do that ?
You can use your phone to record the video. xD
Ahhhhh OK... I thought there way to have bootup and shutdown logs somewhere recorded on the HD...
You can use OpenCore Configurator to generate log. But you'll have to configure several things in order to do that.
pomchik_games
