BLINGVOLDER
Asus TUF B560M-E
Intel I7 10700k
intel UHD 630
I finally installed macOS sonoma on my pc
But there is an issue.
Its so laggy (Like it's animations)
I clicked "About this mac" and it showed me that the Integrated gpu (UHD 630) is 7MB
I tried every methods about fixing this even the dortiana webpage opencore guide, it did not work for me.
How can i fix this?
How can i fix this?
Attach your EFI to check.
Here you go! (Sorry for late reply)
Followed the steps now I get this
Here
Still not as per the guide.
Here are a few issues. Make the following changes to your config.plist:
Disable ResetLogoStatus
Disable ProtectSecureBoot
Set SecureBootModel to Disabled
iMac14,2 is a poor choice for your hardware and moreover, its not a valid SMBIOS for macOS Sonoma. You should use IMac20,1 for the best performance.
Disable IgnoreInvalidFlexRatio. You shouldn't need it for your hardware.
Still having the same issue
delta385852
