AsusSMC on Ventura
1686820795082.png Nothing happened.
bro can you provide the efi file I see our devices are the same
i have problem in config.plist, can you help me, don't know what should i modify in this file.
What problem?
What problem do I get stuck on is the initial installation part, my keyboard works and the mouse does the same and soon the system suddenly crashes and freezes
Provide the EFI you're using to boot the system.
Hello, I have successfully installed macOS Ventura on my laptop, but I am facing some issues. The problem is related to CPU idle usage. When I open the system monitoring in macOS, the CPU idle percentage averages around 95%. This causes my laptop to heat up. In the macOS system, my CPU is detected as Intel Xeon W, and the iGPU is recognized as 512 MB. The second issue is with the trackpad. Sometimes the screen and mouse freeze.
Please create a separate thread to look down into the issues you have.
chrisgamessss
