Random screen glitch and freeze on Ventura (and Sequoia)
I have forgot to share that the same hardware boot W11 on a second disk and it run perflectly well, never ever had any freeze.
If there is an hardware failure, I do not understand why it run so well with W1 and why it freeze with Sequoia.
memtest test only the PC RAM, not the GC VRAM ?
When your say it could be the BIOS, you mean the Gugabyte MB BIOS or the AMD GC Bios ?
My latest EFI attached.
Thx
Here Try this Lil Brother, Im not sure that You Need SSDT-HPET as its for older Laptops etc, I could be wrong. I made a few Adjustments to Your Config.plist. Try and see if it works and YouSSDTs I just rewrote those and no need to list all Processors C000 - C03F Jesus Christ! One is enough with the _DSM Method. Also What is this "USBW" ? And You need to Remap Your USB Ports And when You do that i would use Hackintool If i were You. And dont include The USBToolBox.kext after you Map them, At that point toss the USBToolBox In the trash and only leave the USBMap.kext in your stuff. Use the USBToolBox To get past the brilliant ACPI innovation of subScoping the Fuckin RHUB Ports HS11-HS14 From inside their own Scope. Peace
kcbednar
