SOLVED Graphical glitches and panics when using Firefox
Yup, didn't run into the issue again. So the solution was enabling DisableIoMapperMapping. Marked as solved.
Hey,
Glad that you were able to fix the issue. Just busy weeks for new projects that's why couldn't reply on time
Hey,
No problem! It was a weird issue anyways. There were some problems listed that AppleVTD causes and can be fixed with DisableIoMapperMapping, but none were like this.
This option resolves compatibility issues with Wi-Fi, Ethernet and Thunderbolt devices when AppleVTD is enabled on systems where the native DMAR table contains one or more Reserved Memory Regions and more than 16 GB memory is installed. On some systems, this quirk is only needed when iGPU is enabled.
This is weird because I don't have more than 16 gb RAM. Hackintoshing is weird...
Being not a real Apple hardware can bring some undocumented issues. xD
khoi
